Activity Forums Apple Final Cut Pro Legacy My Final Cut thinks its running on a PowerPC, but its not, help??
  • My Final Cut thinks its running on a PowerPC, but its not, help??
    Posted by Scott Douglas on December 11, 2008 at 2:48 am
    So I’ve got a project for a friend that has the Sony HDR-TRG1 full HD camera that records to flash cards. And when hooked up to the dock, and connected via USB, on Intel Mac’s it should be as simple as doing a log and transfer. Which I have, a MacBook Pro, 2.33 GHz Intel Core 2 Duo, with 3 GB of RAM.
    When I go to open the AVCHD folder on the flash card via the log and transfer window, I get a message saying that “AVCHD media is unsupported on PowerPC based hardware.”
    Does anyone know how I can rectify this situation or if I should be calling Sony or Mac? FCP support or MacBook Pro support? If anyone has any ideas at all that would be a HUGE help!
    Scott
    Kurtis Moser replied 17 years, 4 months ago 4 Members · 5 Replies
  • Jeremy Garchow
    December 11, 2008 at 4:00 am
    Make a new folder and copy the files in their exact form off of the flash card, then try again.
  • Scott Douglas
    December 11, 2008 at 6:14 am
    No dice, it gives me the same message. Thanks anyways tho.
    Scott
    check my stuff out at https://scottkdouglas.com
  • Bret Williams
    December 11, 2008 at 8:36 am
    In the get info for FCP, you haven’t checked the “open with rosetta” box have you? Just a thought.
  • Scott Douglas
    December 11, 2008 at 3:15 pm
    You were right on point! I had it set to open in Rosetta, and thats why it must of thought it was a power pc. Once I unchecked it, everything worked like gold!
    Thanks Bret!
  • Kurtis Moser
    February 18, 2009 at 5:34 pm
    “In the get info for FCP, you haven’t checked the “open with rosetta” box have you? Just a thought.”
    Can you tell me the file tread to get to this “info for FCP”?
