Activity › Forums › Apple Final Cut Pro Legacy › My exported FCP :60 only come out :48 sec?! – frame rate change made
  • My exported FCP :60 only come out :48 sec?! – frame rate change made
    Posted by Stu Aull on June 7, 2012 at 7:39 pm
    So: FCP7, 60sec 23.97 1080p ad
    export to
    29.97 frame rate (no other changes):
    -only renders out to 48sec mark!
    I suspect the frame rate change is causing this, tho what DOES render plays fine, but damned if I can figure out what to reset to allow the WHOLE ad to render its full length?!
    conversion works fine in QT 7 pro.
    odd….
    Stu Aull
    Alaska
    Jeffrey Di lullo replied 14 years, 3 months ago 5 Members · 11 Replies
  • 11 Replies
  • Shane Ross
    June 7, 2012 at 8:07 pm
    What is the codec of the source footage? You didn’t work with H.264 native on the FCP timeline did you? That does this, plus other unpredictable things.
    Shane
    Little Frog Post
  • Stu Aull
    June 8, 2012 at 3:43 am
    Hi Shane-
    ProRes 442 HD 23.98 – trying to re-frame-rate to 29.97. Which it DOES (FCP>Export>ProRes- with appropriate change in FPS) – so I _AM_ getting the 29.97 but only first 48 seconds.
    weird.
    Like I said – QT7 Pro did the conversion (thanks Gawd) but really stumped as to why FCP would do this.
    Stu Aull
  • Stu Aull
    June 8, 2012 at 3:44 am
    Dave-
    I am converting 23.98P to 29.97 _P_ , not _i_
    FWIW
    Stu
  • Shane Ross
    June 8, 2012 at 3:54 am
    Well, you are doing it wrong. That is not how you export to a different frame rate. You need to export a self contained file, then take that into COMPRESSOR and change the frame rate.
    By the way…23.98 to 30p will not look all that good. Because you cannot distribute…create…extra frames by adding fields of video. meaning one frame distributed to 3 fields (1.5 frames) of video. 23.98 to 29.97 interlaced looks great. 23.98 to 29.97 progressive? Not so much. every 4th frame is duplicated…exactly what FCP does when you add 24p to 29.97.
    If you want it to look good, you have to make the output 29.97 interlaced. Unless this is destined for the web or computers, then why are you converting to 29.97?
    Shane
    Little Frog Post
  • Stu Aull
    June 8, 2012 at 4:23 am
    yes, I knew I was doing it wrong… which is why I am here 😉
    The 29.97 frame-rate was client-requested AFTER the shooting, so one does what one can! Will give Compressor a go to see how it looks. thanks.
    But your point makes me wonder if its not better to shoot 29.97P then if someone wants 23.98 it would make more sense to PULL a frame rather than cover up for missing ones going Up the Other Way??
    Thanks for your guidance. Lots to Learn…
    Stu Aull
    Alaska
  • Rafael Amador
    June 8, 2012 at 10:44 am
    [stu aull] “But your point makes me wonder if its not better to shoot 29.97P then if someone wants 23.98 it would make more sense to PULL a frame rather than cover up for missing ones going Up the Other Way??”
    Not really.
    Adding the proper pull down will look as the original stuff, because you are just repeating “fields’. The other way around will drop full frames. Will look more choppy than shot at 29,976.
    rafael
    http://www.nagavideo.com
  • Jerry Wise
    June 8, 2012 at 3:14 pm
    somewhere out there in the forum is a link to a droplet you can use to add pulldown to your project. make a QT of your project, load it into compressor, add the pulldown droplet and the output will time out properly your client will be happy. i use it all the time and it works great for me.
  • Stu Aull
    June 8, 2012 at 7:56 pm
    aaak Jerry! don’t SAY that without a link! torture!
    ;D
    Rafael – re 29.97 pull down – thanks! makes sense as described. so 23.98 it is then.
    really appreciate the hand-holding here guys!
    regards
    Stu Aull
    Alaska
  • Jeffrey Di lullo
    June 10, 2012 at 8:59 pm
    I don’t remember which thread it was on the cow that I pulled these from (if someone can find the orignal thread please post it), but here are the compressor presets to create a ProRes file with correct pulldown.
    4267_proreswithpulldown.zip
    They need to placed in:
    ~/Library/Application Support/Compressor
    Once there make sure the restart Compressor (if it was already open).
    Good luck!
    Jeffrey Di Lullo
    jeffedits.com
  • Stu Aull
    June 10, 2012 at 10:13 pm
    Thanks Jeff!
    will try these out
    cheers
    Stu Aull
    Alaska
