Activity › Forums › Adobe After Effects › my brush tool is not showing up
  • my brush tool is not showing up
    Posted by Caroline Quinn on August 8, 2012 at 7:48 pm
    my brush tool is not appearing in after effects! I clicked the brush tool and the small circle where my mouse would be does not appear. I also am wondering how to click a layer so it is in ‘edit mode’. Again, I am very new to this programs and my questions may sound silly.
    Robert Headrick replied 14 years, 1 month ago 2 Members · 5 Replies
  • Robert Headrick
    August 8, 2012 at 10:04 pm
    To use the brush tool, you need to be working directly on a layer, rather than on your composition (this answers your second question as well). Double-click your layer either in the composition timeline at the bottom of the screen, or directly in the composition window. This will open the layer up in its own tab, and from there you can use the brush tool.
  • Caroline Quinn
    August 9, 2012 at 1:23 pm
    I have tried double clicking the specific layer I want to edit in both the timeline area and in the project window and nothing happens. I’m working in CS6 btw. Is there another way?
  • Robert Headrick
    August 9, 2012 at 1:42 pm
    A couple questions: What type of layer are you trying to edit? Are you using the Standard workspace? (to check this, go to Window –> Workspace –> Standard) If you’re using the Standard workspace already, go ahead and click Window –> Workspace –> Reset “Standard”. Now look up at the top of your center panel that contains your composition view. You should just have one tab that says “Composition: Comp 1” (or whatever custom name you gave it if you’ve named it already). Now when you double-click a layer in your timeline down below, it should open up a new tab right next to the Composition tab that will say “Layer: [name of the layer you opened]”. That’s where you can edit a layer directly rather than working in your composition, and where you should be able to use the brush tool, among other things.
    Let me know how that goes.
  • Caroline Quinn
    August 9, 2012 at 2:07 pm
    Nevermind, I found a way.
  • Robert Headrick
    August 9, 2012 at 2:11 pm
    Awesome!
