Activity Forums Adobe After Effects My Alpha Hell
  • My Alpha Hell
    Posted by Jim Branstetter on June 30, 2010 at 7:58 pm
    Hi All,
    Ok my project has 5 .mov files exported from FCP using compressor with “animation, millions+” settings from FCP using compressor . Each .mov is a edited layer with blank spaces revealing below layers that are rendered out with alpha channel.
    From that I want to build separate comps in AE apply effects, transitions and, fine tune in AE. Then I wanted to compose those comps in a final comp.
    My problem is as a test of the alphas before I started, the alphas were not working in AE, I checked them in FCP they work perfect.
    What I’ve done so far:
    1- Interoperate Footage settings were correct (i thought), alpha straight-unmatted
    2- tried a bunch different mode combos even though it should work without that, but no help
    3- the only way I could get it to work was to use a “Difference Matt” effect with difference layers set to none and all other settings to zero.
    This seems to work but I know its probably not the best way to do this.
    Thanks in advance for the help.
    Jim
    Jim Branstetter replied 16 years, 2 months ago 34,470 Members · 1 Reply
  • Jim Branstetter
    July 1, 2010 at 12:04 am
    Thanks for the response, I exported as you suggested a fcp qt, works perfect. Some glitch in the compressor I guess.
