Activity › Forums › Adobe After Effects › My After Effects Is Take Ages To Do Ram Previews And Render (It Used To Be Fast!)
Posted by Dean Burton-pye on January 18, 2012 at 3:30 pmHi there after moving my computer to a different room it now take very long to start doing ram previews but once it starts it is okay. but this is very annoying as i need to get stuff done quickly.
My PC Specs:
CPU: AMD Phenom II x4 3.2Ghz Black Edition
Ram: 10GB DDR3
Graphics Card: GTX 560 Ti
Any suggestions on how to get it fast again?Michael Szalapski replied 14 years, 7 months ago 3 Members · 7 Replies -
Dean Burton-pye
January 18, 2012 at 3:42 pmI have just tried to render and it does about 1 frame per 45 mins. Please Help.
Dean Burton-pye
January 18, 2012 at 4:00 pmAE Version: After effects CS5.5
OS: Windows 7 Premium 64 bit
all i did once i moved it was cleaned the cpu fan up a little because it was dusty, I really have no idea how it could of effected after effects, but it has. -
Dean Burton-pye
January 18, 2012 at 4:18 pmI have been reading some stuff online and the only things i have done is to troubleshoot my problem, i tried disabling openGL and still had the same problem and tried dedicating more ram to after effects and it had no change, i removed the dust from the case i made sure of it, I am very careful when working inside my case as it contains expensive components, I didn’t add any more stuff to the computer nor remove anything. May i add that the cpu using rises dramatically when starting to do a ram preview and the program stops responding for a while before doing anything, I really cant see what i have done to cause this, as it using to run smoothly as anything with no trouble at all.
Avrohom Kohn
January 18, 2012 at 7:24 pmPerhaps it’s project related… did you continue an existing project to which you can compare that RAM previews were working fine before the move? If not, open an existing project to which you can compare.
Avrohom
Michael Szalapski
January 20, 2012 at 4:23 pmThat seems like a weird little bug.
What happens if you import the problematic project into a new one? Does the problem persist?
Have you reported the bug to Adobe? They’d probably like to see it. https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
