Activity Forums Apple Final Cut Pro Legacy MXO with MacBook pro- basic questions
  • MXO with MacBook pro- basic questions
    Posted by Ed Dooley on July 23, 2007 at 11:53 pm
    Considering a portable editing solution for HDV (with FW ingest). I’m thinking of going with the MXO. Any users (Shane?, Uli?, others?) use an MXO with a MBP. Any 2.0 issues with the MBP or FCS2? I don’t think they’ve fixed compatibility with Color yet, have they? Also thinking of using one 24″ Dell 2407 with MBP closed,
    and using F12 to toggle between FCP and video. Is it as easy as it sounds? I’d like to use a 24″ for FCP and have a 2nd 24″ for video monitor, but it doesn’t sound possible (although a component video monitor does-SD only?)
    TIA,
    Ed
    Ed Dooley replied 19 years, 1 month ago 2 Members · 2 Replies
  • Shane Ross
    July 24, 2007 at 12:01 am
    I use it with my Powerbook…no MacBook Pro yet. Not until this one dies…
    MXO is still not compatible with Color…on any machine. They are working on it. And the MXO works with the older MBPs, but the newer ones…the ones that JUST came out…it doesn’t work with…yet. Apple switched from ATI to NVidia and Matrox is working on drivers to fix those issues.
    [Ed Dooley] “Also thinking of using one 24″ Dell 2407 with MBP closed,
    and using F12 to toggle between FCP and video. Is it as easy as it sounds?”
    Yup…that easy.
    [Ed Dooley] “I’d like to use a 24″ for FCP and have a 2nd 24″ for video monitor, but it doesn’t sound possible”
    You might be able to with the Matrox DualHead2go box. I am playing with that device now. It takes one DVI port and spans it across TWO monitors…boosing the resolution so that instead of 1920×1200, you get 3840×1200 and able to span the image. But then you can’t use the Matrox MXO for the video monitor on one of those. Nope…there are limitations to having a laptop…and freedoms.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Ed Dooley
    July 24, 2007 at 2:09 am
    Thanks Shane,
    I’m so used to looking between timeline and video monitor on the fly with my SD projects that I’m not sure if I’ll be able to toggle back and forth without losing some of the feel (you know what I mean? the stop and go switching between modes).
    I saw this on the Matrox user forum about the DualHead2Go. As you probably know, the DualHead2Go requires a VGA port, not DVI (the response was from a Matrox employee):
    >>>Can I connect the macbook pro 2.33 with a DualHead2Go and the MXO and get two external monitors without any kind of trouble?<<< >>>No, The MXO requires a dedicated DVI port to provide all the benefits of Mastering Mode. <<<
