Activity › Forums › Apple Final Cut Pro Legacy › MXF->ProRes from Canon XF-305, need to set different output directories, Log&Transfer can not do this
  • MXF->ProRes from Canon XF-305, need to set different output directories, Log&Transfer can not do this
    Posted by Go Kudr on October 5, 2013 at 11:05 pm
    Is there any anologues to Log&Transfer?
    Thanks in advance!
    Go Kudr replied 12 years, 12 months ago 2 Members · 4 Replies
  • Rafael Amador
    October 6, 2013 at 2:45 am
    I think you have to install a Canon plugin.
    May be this:
    https://software.canon-europe.com/software/0040354.asp
    There is a ton of info about the Canon workflow in FC.
    Google.
    rafael
  • Go Kudr
    October 6, 2013 at 7:39 am
    Ofcourse, i have already installed this plug
    It appears in Log&Transfer’s codecs menu
    But i need a L&T alternative, because i still cant set different output directories for different csrds.
  • Go Kudr
    October 6, 2013 at 7:53 am
    Another problem is, that if the “filename”-folder contains more than one .MXF-file – only the first one is converted, but the others are NOT!
    How do people manage lots of material? I gues not with the help of L&T.
  • Go Kudr
    October 6, 2013 at 4:13 pm
    Sorry, this one is not a problem. L&T just merges them, if the files are more than one))
