Activity › Forums › Apple Final Cut Pro › MXF is green
MXF is green
Posted by Bret Williams on September 2, 2015 at 2:44 amWhat is this? (see image) I’m trying to import some 4k MXF. Works fine in Resolve and VLC, but not QT or FCP X.
Noah Kadner replied 11 years ago 3 Members · 4 Replies -
Noah Kadner
September 2, 2015 at 3:18 amThat typically indicates the codec in the media hasn’t been loaded. It’s Canon so I’m guessing you need to install a plugin for the specific camera.
Noah
FCPWORKS – FCPX Workflow
Call Box Training -
Bret Williams
September 2, 2015 at 4:34 pmJust learned that it’s XF-AVC from the XC10 which is currently unsupported by FCP X. Resolve 12 has no issues with it and I’m converting to ProRes. But takes a loooong time. About 2 min for every minute of footage. And it’s making the fans in the iMac scream. Looking at getting EditReady software to convert. Says it’s XC10 compatible.
Shane Ross
September 2, 2015 at 5:44 pmDon’t you LOVE it when production shoots with a new camera without consulting post? This happens WAY too often. They just assume it’ll work, no problem.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Noah Kadner
September 2, 2015 at 7:01 pmWhat- no testing of the post workflow before shooting? I’m shocked shocked!
Noah
Call Box Training
