Activity › Forums › Apple Final Cut Pro Legacy › .MXF in QT
Ashley Mcpike
August 13, 2009 at 5:59 pmShane,
I can’t seem to find any P2CMS software that is compatible with a PowerPC they all say you need an Intel Processor.
Shane Ross
August 13, 2009 at 6:27 pmAhhh…right.
Well then, you need one of the other options, the ones that you buy. If you insist on viewing the MXF files natively. Otherwise just LOG AND TRANSFER, and wrap them in a QT file, and join the audio and video. Or just use LOG AND TRANSFER to view them.
Shane
Read my blog, Little Frog in High Def -
Jeremy Garchow
August 13, 2009 at 7:37 pm[Ashley McPike] “I used a Panasonic HD HPX 500 Camera and we shoot the footage in 720P onto a 16GB P2 card.”
Thank you Ashley. You still need an MXF component for Quicktime.
MXF4mac has a component called MXF Qt Import. It allows viewing of MXF files natively in Quicktime, and it is universal binary, but Avc-Intra requires an intel machine.
Calibrated also makes a component that is much less expensive, but hardly as feature rich.
Jeremy
