Activity › Forums › Apple Final Cut Pro › MXF files from Sony FX9 and FCPX
  • MXF files from Sony FX9 and FCPX
    Posted by Ricky Barnes on September 21, 2025 at 9:19 pm
    Hello: After trying hard to import 4k files from my Sony Fx9 into FCPX, all manner of weirdness ensued. Then I finally came to the conclusion files must be converted (Sony Catalyst Browse). I used to do this with my old FCP7 program, but just assumed the X would work. Am I correct in assuming that this is the only option? (other than the other free conversion tools). I’m hoping quality stays pretty consistent? Thoughts? (I could only find relevant discussions from – like, 10 years ago. haha. Thank you kind folks!
    Eric Santiago replied 1 year ago 3 Members · 2 Replies
  • Devrim Akteke
    September 22, 2025 at 6:19 am
    There shouldn’t be any problems regarding importing FX9 footage into FCP. It should be ok since 10.4.2. I don’t know, maybe you did, but running Disk Utility’s First Aid and checking for upgrades – just thinking out loud.
  • Eric Santiago
    September 22, 2025 at 1:05 pm
    Not sure if they are the same format but had a FX6 rental of late and the media worked fine in 10.6.x.
