Activity › Forums › Apple Final Cut Pro Legacy › .MXF files from Iconix lip stick cams into FCP?
  • .MXF files from Iconix lip stick cams into FCP?
    Posted by Sean Kapleton on August 25, 2009 at 8:17 pm
    I realized i mispelled MXF in my original post so hopefully this one will get some responses…I did a search i nthis forum and read a few threads but I am still a little confused / concerned about this workflow.
    SO
    I am receiving footage from two Iconix lip stick cams consisting of two different file forms. One cam has MXF files and one has quicktime files.
    The tech split it out since he wasn’t sure how we were editing. He informed me about this yesterday, rather than discussing on the shoot day. Will we be able to load all this into our system and what would you guys advise?
    thank you
    sean
    John Fishback replied 17 years, 1 month ago 3 Members · 11 Replies
  • 11 Replies
  • John Fishback
    August 25, 2009 at 8:40 pm
    You need to ask what codecs were used to produce the different files. For instance, if the MXFs are DVCProHD, FCP will transfer these files easily. Same is true of the QT files. If they use a FCP codec, you simply copy them to your drive and import them. If both use the same codec (like DVCProHD) the files will be of equal quality.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Sean Kapleton
    August 25, 2009 at 10:05 pm
    I do not have that info at this time HOWEVER when i tried bringing it into log & transfer I got an error message “unsupported media…or invalid media structure”
    thoughts?
    Sean
  • Sean Kapleton
    August 25, 2009 at 11:13 pm
  • Jeremy Garchow
    August 26, 2009 at 9:30 am
    MXF is simply a container. What do the files actually look like?
  • Sean Kapleton
    August 26, 2009 at 2:43 pm
    What do you mean by what does it look like?!
  • Jeremy Garchow
    August 26, 2009 at 3:09 pm
    [Sean Kapleton] “What do you mean by what does it look like?! “
    Sorry, should have been more specific. What’s the file structure? Take a screen grab of one of the MXF files in your finder and post it here.
    Jeremy
  • Sean Kapleton
    August 26, 2009 at 6:42 pm
  • Jeremy Garchow
    August 26, 2009 at 6:47 pm
    If you are allowed and file size permits, can you upload one of the smallest MXF files? I can tell you if MXF4mac works on these files.
    If you want to take this offlist, hit me up at editstation at gmail dot com
    Jeremy
  • Sean Kapleton
    August 26, 2009 at 7:01 pm
  • Sean Kapleton
    August 31, 2009 at 2:26 pm
    Sorry for the late response
    the smallest file i have is something like 130 mb so i’m guessing that doesn to make sense?!
    what about bringing it into avid and exporting uncompressed 10 bit qt’s?
    i just tried it actually and i get error messages in avid – i’m thinking to post i nthat forum now too wit hthese screen grabs to see what Avid peeps think
    any thoughts?
    thanks
    sean
