MXF files from EX3 to FCP7 – best workflow
Hello guys
I’ve got these .mxf files from sony ex3
Trying to figure out how to manage them in fcp7
I see there some expensive mxf/qt converter for mac but I’m looking for a cheap but correct solutionI read of this trick but I can’t verify how professional it is and if it works:
– import the mxf files into your fcp project in the same way you do with mov files
– the software will obviously tell you they’re not good and bla bla bla…
– with the Media Manager tool re-compress them in appleprores422LT into a new projectanyone tested this workflow?
does it work?any suggestions are more then welcome!!!!
thank you in advance
