Activity Forums Avid Media Composer MXF File Export from AVID Symphony
  • MXF File Export from AVID Symphony
    Posted by Benjamin Becker on June 3, 2010 at 4:34 pm
    Hey there,
    i have the following Question:
    Is it possible to Export an MXF File from AVID, in order to manually drop it on an
    XDCAM HD Recorder via LAN? As far as i know you can only output a sequence to a
    locally connected XDCAM via Firewire/USB. Is that correct?
    Or is there any way to export a single MXF File?
    Maybe there is a way to emulate an XDCAM HD Deck on the AVID System?
    The reason for this is simply that our XDCAM HD is not locally connected to the AVID System but 2 floors above…….
    Any ideas are appreciated!
    Benny
    Benjamin Becker replied 16 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
