MXF Export issues with PP5.5
Using Premiere Pro 5.5.
I am trying to export a clip using the “match sequence settings” of PP. That results in a P2 movie format (DVCPRO50 codec) MXF file. I have tried encoding this twice now however it is NOT showing up anywhere in the output folder I have selected with the file name I have selected. It’s going to an external HDD – I have checked the entire drive and there is nothing.
No error message, no crash. The status bar goes up to 100% and then closes like it has encoded fine.
However, within a folder called “CONTENTS” there are sub folders, within “Video” there are a batch of MXF files (which I am unable to play with any programme on my PC)/ If they are the exports I have been making, it looks like the audio has been separated from the video as there is a separate audio folder. This is an issue as I am encoding to upload to Flow Player, a video hosting site which has requested my project with no treatment / encoding on the export different to the source material.
Does anybody know what is going on here? Thanks for any help.
