MVP 14 and Contour Shuttle Pro not working
Posted by Scott Francis on September 28, 2016 at 12:30 amAny one using a Contour Shuttle Pro with MVP 14? Mine works on SVP 13 but not MVP 14, anyone else have this, anyone able to fix it?
Thanks in advance!!
Xavier (Scott) Francis
Mind\’s Eye Audio/Video ProductionsSteve Rhoden replied 10 years ago 4 Members · 5 Replies -
Graham Bernard
September 28, 2016 at 3:04 amI do. Did you install the CSP2?
* Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Scott Francis
September 28, 2016 at 3:42 amSince I am unsure of what that is, I don’t think I did, what is that?
I installed the drivers and control software a while back…Xavier (Scott) Francis
Mind\’s Eye Audio/Video Productions -
Mark Barton
September 28, 2016 at 4:16 amYou need to go into the Shuttle Pro control panel and import the settings file found in the VP14 directory. It does the controls based on the executable running at the time. If you customized your a lot, then you may just want to edit/copy it so it is associated with the vegas140.exe
BTW, my ShuttleProv2 is working fine after I made this change, which I have to do anytime I upgraded Vegas in the past.
Scott Francis
September 28, 2016 at 5:16 amThat did it!!! Thanks so much! I had to do that in the past, but not for SVP 13 for some reason and I had forgotten how to get them to communicate. SVP13 has been around SOOOO long it has been like 3-4 since I had to import them.
Again, thanks so much!!
Steve Rhoden
September 28, 2016 at 10:34 amGlad you got that sorted. Had to import the host settings for every previous Vegas versions.
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
https://www.facebook.com/FilmexCreativeMedia
