Activity Forums Apple Final Cut Pro Legacy mute audio on capture
  • mute audio on capture
    Posted by Bruno Dinis on October 29, 2008 at 10:24 am
    Hello Everyone.
    its the first time I use this forum, i’m just a newbie.
    Well..
    I use final cut every day and its annoying to listen the audio while i’m capturing.
    How can I mute the audio channel while i’m capturing? So I can listen music for example?
    Thanks a lot.
    Mihai Gal replied 15 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Alex Elkins
    October 29, 2008 at 3:30 pm
    Hi Bruno – welcome to the forum.
    Are you capturing using a video card (Kona/Blackmagic etc) or through Firewire? If you’re using a card then under System Preferences>Sound you can set your output to Internal Speakers for your music to come out through the Mac speakers, or Line Out if you’re using headphones/ external speakers with a mini-jack connection.
    Best,
    Alex
  • Bruno Dinis
    October 29, 2008 at 3:37 pm
    Cool.
    Thank you so much.
    You made my day 🙂
    Now I can ear some music while capturing long and boring shoots.
    tks again
    Bruno
  • Andrew Gurney
    October 29, 2008 at 5:32 pm
    Alternatively. In the log and capture window under the clip settings tab, uncheck the Preview Box and that should mute your incoming audio.
  • Bruno Dinis
    October 29, 2008 at 5:35 pm
    that way is easier, in fact, but under the ‘clip Settings’ tab I just have:
    -video
    -audio
    -create new clip on Start/Stop
    should I uncheck the audio here?
    Cheers
  • Andrew Gurney
    October 29, 2008 at 5:41 pm
    No, you won’t want to uncheck the audio box as that means you’ll just capture Video.
    What version of Final Cut are you using?
    Do you have any other options in the audio section, like input channels, or input levels?
  • Bruno Dinis
    October 29, 2008 at 5:45 pm
    – Yes, makes sense.
    – Final Cut Pro 6.0.4
    – No, I’ve just searched, but no lucky.
  • Mihai Gal
    July 21, 2011 at 5:46 am
    Seems that there is no way to mute the audio while capturing HDV footage at this stage…until FCP come with a plug in or something.
    One option I found that works for me if when I filmed, I recorded on one channel only.
    If the audio is recorded on your RIGHT channel then go in to the
    system preferences > sound > output
    and change the balance to the LEFT opposite of how you’ve recorded the audio on your footage.
    That way you won’t hear the sound of your footage while you want to listen something else on your computer. But you will be able to listed in mono only. Its better than nothing ey?
    Hope that this helped.
    Mike
