Activity › Forums › Apple Final Cut Pro Legacy › Must render audio on most of timeline each time I make a cut…
  • Must render audio on most of timeline each time I make a cut…
    Posted by Chris Fera on January 31, 2011 at 7:20 am
    Hi there,
    I am having an issue with the sound on my timeline. All the sequences that have more sound tracks (effect, music, room tone…) must be rendered each time I perform a cut on the timeline or simply drag and move the scene to a different position. I have two external western digital hard drives with 400 firewire connection… any way to avoid this? Thank you.
    Matthew Miller replied 15 years, 7 months ago 4 Members · 4 Replies
  • Chris Tompkins
    January 31, 2011 at 2:25 pm
    What format is your audio? Not using mp3 are you?
    Make sure you’re using Broadcast wav’s or 48k aif’s
    Also check your real-time settings for audio:
    Chris Tompkins
    Video Atlanta LLC
  • Zane Barker
    January 31, 2011 at 3:48 pm
    What you are putting in your timeline does not match your timeline settings.
    **Hindsight is always 1080p**
  • Chris Fera
    January 31, 2011 at 7:18 pm
    Hi guys, it was my real time audio tracks… it was set at 8. I changed it at 16 and it’s all good now. Of course I am not using mp3 😉 only wav thanks a lot!
  • Matthew Miller
    February 10, 2011 at 3:55 am
    few, thnx
