Music video – walk me through the conversions?
I’d like to edit together a music video for YouTube, using the following three original files:
– an AVI that is 640×480, 30fps, 14.95Mbps (with audio at 11.024kHz, 88kbps – this audio will not be used in the final)
– an MP4 that is 1280×720, 29.642fps, 11.86Mbps (with audio at 48kHz, 63kbps – this audio will not be used in the final)
– a WAV that is 44.1kHz, 1411kbps (this will be the final audio, exclusively)
I’d like the final product to be 1280×720, with black bars on right and left when the video from the AVI is used.
I tried converting the video files to Apple Pro Res 422 in Compressor, but when rendering, sync would go wildly and randomly out.
To what format(s) should I be converting each of these three files in order to have a smooth and successful project with minimal rendering?
Thank you in advance.
