Music Video Audio Rate Problems
Hi guys,
I am currently editing a music video that was shot on the RED and converted into Pro Res.
I have been working using a guide track recorded live with the format:Audio rate – 48.0 KHz
Audio Format – 32-bit IntegerI have now received the full quality track from the band.
The problem is that the format of this track is:Audio Rate – 44.1KHz
Audio Format – 16-bit IntegerI have tried converting the track’s Rate to 48.0KHz through Compressor but just can’t get the tracks to sync.
If anyone has any advice or if you can see that I am making an obvious mistake please let me know.
–Thanks a lot.
–Robbie
