Activity › Forums › Avid Media Composer › music tracks – replace
Posted by Rap on November 26, 2005 at 1:08 pmHi guys,
IJustin Coleman replied 20 years, 10 months ago 3 Members · 2 Replies -
Michael Phillips
November 26, 2005 at 5:17 pmSelect the low rez version and batch reimport the files. See if that works. I know it does for WAV and BWAV files. Make sure you point to the right file first…
Justin Coleman
November 26, 2005 at 8:31 pmYou must make sure that you turn off the match exact file name option in the import tool or it won;t let you replace it. Just double check that the files are the same length etc or it might not edit them into the timeline correctly.
