Activity Forums Adobe Premiere Pro music track sound quality in Premeire pro seriously degraded
  • music track sound quality in Premeire pro seriously degraded
    Posted by Phil Vanderloo on January 19, 2017 at 3:44 pm
    I’ve been using premiere pro for a few years now and never had this issue before.
    When I play mp3 or .wav files in quicktime player they sound great.
    But playing in the source panel in premiere pro 2017 cc, the sound quality is severely degraded. I posted yesterday with no fix offered so I thought I might need to clarify in a repost
    The only difference from before is that I just got some new Sennheiser headphones, (bluetooth), but again everything sounds fine in qt player.
    At first I had no sound in premiere pro til I switched the audio hardware input to headset microphone (handsfree bluetooth audio), and the output to Out (headphones bluetooth handsfree audio). Now I have sound but really bad sound.
    Is there something else I should be checking?
    Thank You
    Phil Vanderloo replied 9 years, 7 months ago 1 Member · 2 Replies
  • Phil Vanderloo
    January 19, 2017 at 8:18 pm
    As it turns out Dave, The problem is an issue with my new bluetooth headphones. I had a feeling that might be related because I never had this problem before installing them. So i plugged in a cord and went direct to the headphones and everything is fine.
    I hope I can find a way to switch back to bluetooth to avoid the cord. I’m sure it’s a setting in the audio hardware settings but I think I tried every conceivable combination, (of available choices), and nothing worked.
    Thank You
  • Phil Vanderloo
    January 19, 2017 at 9:01 pm
    Ya and I should have mentioned in my last post that converting the files to .wav was one of the first things I tried and it didn’t help/
