Activity Forums VEGAS Pro music problem
  • music problem
    Posted by Jo ann Robisheaux on January 5, 2009 at 4:26 am
    After I publish the video, the music just stops randomly. Plus, the timing is off even though it was correct before I published it. Any ideas?????
    Steve Rhoden replied 17 years, 8 months ago 3 Members · 2 Replies
  • Craig Patterson
    January 5, 2009 at 4:42 pm
    Hi-
    I can’t address the dropout issue based on the information you’ve given, but the timing issue is usually because Enable Frame Snapping was turned off during your editing process. All the video edits must take place on frame boundaries, or the video stream will drift out of sync with the audio when rendered.
    Craig
  • Steve Rhoden
    January 5, 2009 at 5:52 pm
    As Craig said….you need to be more specific about your
    description still….and what versions you are using…
    (when you say publish)
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Portfolio at:
    http://www.youtube.com/hentys
