Activity Forums Adobe Audition Multitrack Recording: Can I Create A Preset Of The Input Routing Assignments That Can Be Recalled?
  • Multitrack Recording: Can I Create A Preset Of The Input Routing Assignments That Can Be Recalled?
    Posted by Steven Broido on January 16, 2019 at 6:06 am
    Here is my current workflow:
    1) I open Audition
    2) I click Multitrack to create a new multitrack session and name the sessio and specify where it gets saved.
    3) I customize what feeds get sent to what tracks (Example: Mic 1 goes to Track 1, Mic 2 goes to Track 2, Mic 3 goes to Track 3, A mix of all the mics goes to Track 4)
    5) I record and save the session. Then retrieve all the isolated track recordings as needed in the folder i created.
    If I want to do the same exact thing tomorrow, is there a way to recall the channel input assignments I made yesterday?
    Right now I need to manually reset each input source each time I do a new multitrack recording.
    A workaround is to reopen the last project with the correct mappings, do a save as and start a new recording… but that seems clumsy.
    I can’t imagine that Adobe doesn’t have a way of saving a preset for this ….
    Am I missing something?
    Thank you SO much in advance!
    Steve
    Tom Sefton replied 7 years, 7 months ago 2 Members · 1 Reply
