Activity › Forums › Adobe Premiere Pro › Multiply and Screen keys not working in PPro 2?
  • Multiply and Screen keys not working in PPro 2?
    Posted by Five Talents on October 21, 2007 at 5:16 pm
    Hi all,
    When I apply Multiply or Screen key to a track I can’t seem to see any effect on the final output… no matter how I adjust the opacity or cutoff parameters. I have applied the similar effect on Premiere 6.5 and it works as expected (darken/whiten the video track below with the video from the keyed track.) I have tried to use a clean OS install and a clean PPro 2 but the problem is the same. BTW, all other keying effects work with no problem.
    Has anyone experienced a similar situation? I am not sure what goes wrong here. My HW and SW spec are as follows:
    AMD Opteron 170 Dual Core, 2 GB RAM
    Windows XP Pro SP2
    nVidia 6600GT, ForceWare 93.71
    Premiere Pro v2.0 (T316-11/17/2005) (copied from Help/About)
    Thanks for your help!
    Paul
    Five Talents replied 18 years, 11 months ago 2 Members · 2 Replies
  • Mike Velte
    October 21, 2007 at 7:07 pm
    That might be why both keys are not in CS3. Of course AE can do.
  • Five Talents
    October 23, 2007 at 2:17 am
    Thanks for the reply. Yes, I can use AE to do that (I have AE 7), but for a simple editing I prefer to stay in PPro as much as possible (I don’t have production bundle/dynamic link so interacting between PPro and AE means rendering.)
    I got a tip from a friend to get this working to some degree: creating a sequence to contain only the “masking” track, then applying the multiply/screen effect to this sequence within a master sequence which contains the underlying video. With this way I can see the multiply/screen effect on the master sequence. However, the effect parameters (opacity and cutoff) are essentially useless – any touch on them will disable the effect completely.
    Unless someone has a better answer, I think these two effects are somehow broken in PPro 2. I am surprised that I did not see many complaints on this (maybe everyone assumes AE for this type of work and never use these effects in PPro.)
