Activity › Forums › Adobe Premiere Pro › multiply and screen blending
Posted by Gints Apsīts on November 3, 2007 at 3:22 pmhow can i set something like multiply and and screen transparent blending for layer element above like i do it in AE and PS? thnx
Waldo Vargas replied 12 years, 5 months ago 11 Members · 15 Replies -
Gints Apsīts
November 4, 2007 at 9:46 pmim making editing. so i thought it would be easier if i simply do it PR, instead of jump between 2 packages. if im correct this otion was in previouse version of PR.
Perry Cheng
November 6, 2007 at 5:52 amMike,
Is it possible to copy these effects into the plugin folder from CS2? It is really non-sense for Adobe to get rid of them. Yes, I understand even in 2.0, they don’t work very well, but at least there are some get around. Now CS3, there is none. Why not try to make it work, but get rid of them and dump down Premiere (Should Premier no longer be called premiere but ‘Average’ instead? I am becoming less and less enthusiatic about this product. Vegas seems have more bells and wisels and cheaper. Yes, the interface needs get used to, but HDV, 24p, Plugins… much more flexibility. The only advantage staying with Adobe is for the suite, nothing more.)Perry
Mike Velte
November 6, 2007 at 11:08 amYou can copy/paste effects from Photoshop and AE into Pro, some work, some dont.
Tim Kolb
November 6, 2007 at 2:10 pmThere used to be an effect that you could use in the PPro program to apply Photoshop-like layer blend effects…not sure if it’s still in there.
I’m not in front of my machine right now and I’m trying to remember what the heck it’s called…”calculations” maybe?
TimK,
Director, Consultant
Kolb Productions,Creative Cow Host,
Author/Trainer
http://www.focalpress.com
http://www.classondemand.net -
Vince Becquiot
November 7, 2007 at 2:24 amI do agree, we need these back, they should actually all be there, and working. This is a tool I use quite a bet with multiple layers to add mood to a shot, so going back and forth with AE can be a pain.
Of course if you have the budget for a colorist and an special effects team the issue goes away 🙂You can apply the “blend effect” in CS3, was that also in CS2, I can’t recall?
That’ll get you color, tint, darken, and lighten.
Vince
Gints Apsīts
November 8, 2007 at 7:55 pmthanks Tim with fx “calculations” i got what i was looking for. thanks.
Fabrica De desene
January 18, 2008 at 11:07 pmI followed the steps: Effects>Channel>Calculations then go to Blending Mode and choose Multiply from a list that looks exactly as the PS’s one. And it did not work. it seems like the layer I want to apply the effect on does not change at all. Do you have any idea why?
Jon Barrie
January 19, 2008 at 2:09 amMake sure the second source is setup to the correct layer. For example if you want layer 2 (your effect placed clip) to overlay the layer 1 video, the second source needs to point to the layer 1.
– jon 🙂How many editors does it take to change a light bulb?
