Activity Forums Adobe Premiere Pro multiply and screen blending
  • Fabrica De desene
    January 20, 2008 at 3:24 pm
    Yes, 10x guys it’s working 🙂
    the only problem is that you can affect only one track, but it’s fine.
    🙂 I’m not an editor actually, but I know that you need at least 5. One has to hold the bulb and the other 4 have to rotate the table.
  • Qiu Jiaqiu
    February 12, 2008 at 4:44 pm
    thank you very much!!!
    解决了我大问题!
  • Sunny Sawrav
    June 4, 2013 at 4:23 pm
    Hi there,
    You can use it to blend on multiple tracks. All you need to do is select them all and nest them together. Then select the layer where the nested sequence lies as the 2nd layer.
  • Ashutosh Moharana
    December 9, 2013 at 5:19 pm
    Just a simple process. In Premiere you can use the calculation and specify the 2nd video layer.
  • Waldo Vargas
    April 9, 2014 at 7:33 pm
    You can also use Boris Continuum (BCC Composite) which has an extensive toolset for composition within Premiere.
    Mograph Consultant
Page 2 of 2
