Activity Forums Apple Final Cut Pro Legacy Multiple timeline markers in same position
  • Multiple timeline markers in same position
    Posted by Tom Berger on October 6, 2010 at 4:48 pm
    Does anyone know of a way to place two timeline markers at the exact same location? I have done this by accident (two markers were combined with a ripple delete), but cannot seem to do it intentionally.
    I work in animation and use the markers to designate clips as “shots” and then a range of shots as “sequences”. The marker info gets pulled from an XML to cut up the Quicktime.
    Ronald Czarnecki replied 13 years, 11 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    October 6, 2010 at 5:50 pm
    The most you can actually add is one per frame.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Matthew Bradshaw
    October 6, 2010 at 7:25 pm
    Not so. With no track selected you can add a marker to the timeline and with a clip in a track selected you can add another. Easy.
    Matt.
  • Jerry Hofmann
    October 7, 2010 at 12:20 pm
    You’re talking about adding a clip marker – only one can be added per frame within a clip. Tom is asking about 2 sequence markers on the same frame, which you cannot do.
    When you export a sequence, only the sequence (Timeline) markers would be part of the XML that Tom’s after.
    Jerry
  • Ronald Czarnecki
    October 3, 2012 at 2:35 pm
    Two markers on the same frame. Done in FCP 7
