Activity Forums Maxon Cinema 4D Multiple splines following same path
  • Multiple splines following same path
    Posted by Jonathan Fleck on April 8, 2010 at 1:53 am
    Hi folks,
    I want to create 5 winding splines that run adjacent to one another. For example, the splines should be like a winding road, or river. The outside bends should be wider than the inside. The lines should remain equidistant throughout. Using the ‘Create Outlines’ function in C4D does not create a satisfactory result, and brings the lines closer together on longer stretches. Here’s an image to illustrate – https://jf.cx/bends.jpg – C4D, when using the Create outlines function creates a result like the bottom set of lines, compressing the distance between the lines in one of the dimensions. The 2 sets of lines above are exactly like what I want – how can I achieve this directly in C4D?
    Thankyou!
    Jonathan Fleck replied 16 years, 5 months ago 2 Members · 2 Replies
