Activity Forums Adobe After Effects Multiple shots on duffirent layers not importing from PP CC
  • Multiple shots on duffirent layers not importing from PP CC
    Posted by Jonathon Sendall on May 15, 2014 at 4:25 pm
    Have a short sequence I’m importing from PP CC into AE. The shots in PP are lying on top of each other at the same point as I need to pull different elements from each and comp them togehter to make one shot. Layers are no more than four. When I import to AE I just get the cuts from shot to shot and not the multiple layers.
    I have tried importing and opening the PP proj file in various ways but always the same result. I even tried removing all effects just in case that created aproblem but still the same result. Some footage is 720p and some 1080p but I didn’t think that would make a difference.
    Any ideas?
    Cheers
    Jeff Hinkle replied 12 years, 4 months ago 2 Members · 1 Reply
  • Jeff Hinkle
    May 15, 2014 at 6:18 pm
    From Adobe Help:
    In a sequence, select the clips you want in the composition.
    Right-click any of the selected clips.
    Select Replace With After Effects Composition.
    It is easier to destroy than to create.
    More fun, too.
