Activity › Forums › Panasonic Cameras › Multiple ShotPut Pro running at the same time
  • Multiple ShotPut Pro running at the same time
    Posted by Matthew Romanis on June 10, 2009 at 9:53 am
    Hello all,
    Can any of the file handling programs such as Shot Put, handle multiple cards at once?
    Can I use a PCD 25/35 loaded with 5 cards and simultaneously off load the data to 2 drives with 5 separate folder destinations?
    Matthew.
    Matthew Romanis replied 17 years, 3 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    June 10, 2009 at 3:13 pm
    Sure can. You start each card one by one, but you can use Shot Put Pro to offload 5 cards at once.
  • Matthew Romanis
    June 10, 2009 at 10:10 pm
    Thanks Jeremy,
    I tried that and got an application conflict error and a file in/out error.
    Is there a known software conflict? I might have something loaded that’s causing an issue.
    Matthew.
  • Jeremy Garchow
    June 10, 2009 at 10:21 pm
    Make sure you have the latest up to date Shot Put Pro and the PCD35 drivers.
  • Matthew Romanis
    June 11, 2009 at 10:54 pm
    Yep, all that.
    I’ve been checking on some other sites and the suggestion is that having Perian loaded can cause issue with some P2 applications. Has anyone experienced this?
    Matthew.
