Multiple Sequence Workflow: FCP X Workarounds
Hi all,
I just finished interviewing ~20 people on camera. As I re-watch my interviews, I hope to pick out 5 or so major themes, which I’ll connect to create a mini documentary.
When editing in FCP7, I’d create a new sequence for each theme, open all sequences up as tabs, and drop the relevant clips from each interview to the relevant tab. I’d then polish up each individual sequence, and throw it into a master timeline for final editing.
I’ve found 2 workarounds for this in FCPX, but they both fall short. Curious to know whether you have any other suggestions.
Workaround 1: Create 5 different projects, treat those as my sequences. Problem: The projects are alphabetical, and my sequences have a specific order that I’d like to keep. I can number them to force this order, but it’s a pain especially as new themes / sequences may arise as I’m viewing video (In FCP 7 I’d simply drag-and-drop the tabs into the order that I wanted).
Workaround 2: Create 5 compound clips, one for each theme or sequence. Problem: The compound clips don’t have any labels, so hard to tell which compound clip is for which theme.
Thoughts?
