Activity Forums Maxon Cinema 4D Multiple parameters in Texture tag Selection field?
  • Multiple parameters in Texture tag Selection field?
    Posted by Eric Chard on December 2, 2019 at 8:04 pm
    With an extruded object you have the 2 premade selections, C1 and C2.
    When restricting a texture to BOTH C1 and C2, must one use two >>tags<
    Steve Bentley replied 6 years, 9 months ago 2 Members · 1 Reply
  • Steve Bentley
    December 11, 2019 at 5:42 pm
    I have a memory of this (with a comma between) but I might be smoking something.
    I don’t think there is. If there was you would be able to select two selection sets and then drag them both into the selection area of the material attribute at the same time and that doesn’t work. That double drag would create the proper syntax in the selection area but instead you get a verboten icon.
