Activity Forums Adobe After Effects multiple objects from one layer
  • multiple objects from one layer
    Posted by Dan O’brien on March 12, 2007 at 2:26 am
    I don’t know if there’s an easy way to do this, but I need to take an image (a tree) and put it in a 3d comp many times throughout the landscape I’m building. They need to be in different positions (x,y, and z). Is there a way to do this with 1 layer, or do I have to put the same image in my comp multiple times and reposition them manually?
    Mike Clasby replied 19 years, 6 months ago 2 Members · 2 Replies
  • Mike Clasby
    March 12, 2007 at 3:04 am
    You do need multiple layers, IMHO. You might try this expression on a 3D layer’s position:
    minX = -500;//Minimum x depth value
    maxX = 1000;//Maximum x depth value
    minZ = -500;//Minimum z depth value
    maxZ = 2000;//Maximum z depth value
    seedRandom(index, true);
    x = random(minX,maxX);
    z = random(minZ, maxZ);
    [Math.round( x), position[1], Math.round( z )]
    This gives them all the same Y value, you can move them manually since they are probably more critical. Worth a try.
  • Mike Clasby
    March 12, 2007 at 3:05 am
    My mistake, put the expression on the tree layer and then Ctrl D until you have as many layers as you want.
