Activity › Forums › Adobe Premiere Pro › Multiple machines working with the same file
Posted by John Martinez on February 18, 2008 at 1:08 amCan anyone point me to some good information about how two machines can work on the same Premiere file (but not at the same time) without having to relink the files?
Thank you
John Martinez
http://www.reselleradvocate.comJeff Brown replied 18 years, 7 months ago 3 Members · 4 Replies -
Jon Barrie
February 18, 2008 at 2:32 amYou need to have the project and all files on an external HDD. The HDD needs to be setup with a dedicated Letter that won’t conflict with any other systems HDDs.
Goto> Start button>Control Panel>Performance and Maintenance> Admin Tools> Computer Management> Disk Management > Find the Drive Right Click on it and change Drive Letter and paths. Set the Letter. (ie: Z)
Everytime the ext HDD loads into someone elses computer it will always be looking for the file directory inside the same HDD path name.
– Jon 😉
How many editors does it take to change a light bulb?
John Martinez
February 18, 2008 at 2:42 amJon, thanks for the reply.
Can I ask three more questions?
1. With the example you give using an external hard drive, are you saying unplug and move the drive to the other computer when you want to change machines?
2, If so, is there a way to use shared storage – NAS or SAN – to do the same thing over our internal network?
3. Are there issues of speed using an external hard drive – firewire/USB vs eSATA/SATA/SAS?John
John Martinez
http://www.reselleradvocate.com -
Jon Barrie
February 18, 2008 at 6:29 amCan I ask three more questions?
Sure…1. With the example you give using an external hard drive, are you saying unplug and move the drive to the other computer when you want to change machines?
Yes…2, If so, is there a way to use shared storage – NAS or SAN – to do the same thing over our internal network?
I’ve not done it personally, but I’m sure if the network drive is being used with the same HDD Name (letter) on all drives and is seen on all workstations through the same drive path it should work. You can’t save project over a network tho. That has to be saved on the HDD directly connected to the workstation (why an Ext. HDD solution works so well).3. Are there issues of speed using an external hard drive – firewire/USB vs eSATA/SATA/SAS?
I use Firewire Only as they can be daisy chained to each other and I never run out of ports, unlike USB. USB 2 is the only version of USB worth using for Video, but even then it’s not that great. Most Pro Editors will tell you they use FW only. eSATA sounds great, never used it though.– Jon 😉
Jeff Brown
February 18, 2008 at 1:57 pm[Jon Barrie] “You can’t save project over a network tho. That has to be saved on the HDD directly connected to the workstation”
I save PPro project files to a shared network drive (on a fileserver) almost daily. You may have reasons for saying otherwise…
I do keep media files local.The only way to get reliable media playback in a networked situation would be with a SAN of some sort. Not for the faint of heart or faint of wallet.
