Activity Forums Adobe After Effects Multiple lines on stroked path.
  • Multiple lines on stroked path.
    Posted by Moog Gravett on March 6, 2013 at 12:51 pm
    Hi folks,
    I’m trying to work out a way to stroke many lines along a path in a controlled way.
    Imagine having a path, perhaps with a loop in it, then wanting to draw a rainbow along that path, with each colour being a separate entity.
    Or perhaps the lettering on a 70’d disco record sleeve.
    Can’t seem to dig up much about that?
    Any ideas?
    Cheers
    M
    Freelance | Video Editor | After Effects | Camerawork
    http://www.Peculiana.com
    Moog Gravett replied 13 years, 6 months ago 3 Members · 3 Replies
  • John Cuevas
    March 6, 2013 at 2:52 pm
    You need to look into using shape layers and repeaters. In conjuction with color map below you could probably make that 70’s disco look. Also you can change text layers into shape layers if you need the text to be repeated.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Paul Roper
    March 6, 2013 at 3:17 pm
    If you can live with the same colours appearing each side of the line, then you can just add multiple strokes to a line, making each one pregressively fatter as you go, like this:
    …which is actually a whole bunch of strokes over each other.
    – Paul
  • Moog Gravett
    March 6, 2013 at 9:03 pm
    Thanks guys,
    I’ll have a play tomorrow.
    Out of interest, how would it usually be done? I’m presuming set up in illustrator and then animated?
    cheers
    moog
