Multiple invigorator layers
I am using invigorator to create an opening box with objects flying out once opened. I have used one instance of invigorator to create a cube without a top, added a thin primative as the lid and 1 main objet jumping out of the box then animated a camera around the box in ae.
the problem i have is i need 10+ objects to fly out of the box once opened, and with only 8 sets i tried to do 8 in one and 2 in another.
The problem is that the new instances of invigorator are appearing behind the open lid which ruins the illusion, i tried re arranging the layers in after effects but you can see the shapes infront of the box which doesnt work too. All are using the comp camera, how come multiple instances of invigorator (using the Comp Cam) do not interact?
