Activity › Forums › Adobe After Effects Expressions › Multiple if/else statements
  • Multiple if/else statements
    Posted by Thomas Collier on June 1, 2020 at 6:48 pm
    Hello,
    I have four check boxes. They are set up to turn each other off (driving visibility of layers), for example if 2 is turned off, 3 and 4 and turned off. If 3 is turned off, 4 is turned off.
    I am trying to drive a time delay based on which switch is off. If switch 2 is off, I want a shorter delay than if all switches are on.
    I have set up the time delay for the last layer (all layers on) and the time delay works correctly. How do I approach adding the other switches?
    if(comp("Network Lineup").layer("Controller").effect("Network Logo 4")("Checkbox")==0)transform.yPosition;
    else valueAtTime(time-.6);
    Thomas Collier replied 6 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
