Activity Forums Adobe Photoshop Multiple files into one PSD file
  • Multiple files into one PSD file
    Posted by John on November 4, 2005 at 7:54 pm
    Does anyone know of a way I can select muliple jpegs in a folder and have them automatically import into one psd file seperating each jpeg onto it’s own layer and keep the original file names with that layer? I have done this done this in a back door method by pull all my files into After Effects and creating a comp then saving that comp as a PSD file but this doesn’t work with the current files because some of them are CMYK wich After Effects does not read.
    Richard Harrington replied 20 years, 10 months ago 2 Members · 1 Reply
  • Richard Harrington
    November 5, 2005 at 11:18 pm
    If they are sequentially numbered… you can import them in Image Ready into one document
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
