multiple expressions on one track over time – How?
Hi
Is it possible in AFX 7 to have on one track at different times different expressions?
For instance, I draw an L-shaped line with Write-On effect.
for the horizontal segment at frames 1..15 Brush position takes only an X from the master null object, and for the second segment at frames 16..30 it should take only Y from the master null (motion tracker data).Is it possible to keyframe expressions? =)
Or what is the alternative?
