Activity Forums Apple Final Cut Pro Legacy Multiple exports of the same file as ProRes= Loss of quality?
  • Multiple exports of the same file as ProRes= Loss of quality?
    Posted by George Ovcinikov on May 29, 2011 at 1:55 am
    Hi, I was not sure under which category to post this question, because it relates to more than just Final Cut Pro. I am sorry I chose the wrong one.
    I am working on a short film which includes a lot of shots that need to be worked on with After Effects. I realised that i will have to export the shots several times: from final cut to after effects to do effects, then from after effects back to FCP, then once the edit is complete i will export the whole sequence again and import it into after effects to do final color correction. The final Quick Time file will be exported from AF.
    My question is: Even tough I export as ProRes 422 every time. Will these multiple exports diminish the quality of my clips?
    Thank you.
    George.
    George Ovcinikov replied 15 years, 2 months ago 2 Members · 2 Replies
  • Andrew Rendell
    May 29, 2011 at 6:37 am
    If you are always in ProRes422 there won’t be any inherent loss of quality by passing the shots through different software. You get a loss of quality if you transcode between different codecs. (It’s possible that you might degrade some aspects of picture quality in doing some effects, but that’s a different issue).
  • George Ovcinikov
    May 29, 2011 at 12:06 pm
    Thank you for your answer.
    Phew, now all my exporting worries are gone.
