Activity Forums Apple Final Cut Pro Legacy multiple clip formate
  • multiple clip formate
    Posted by Ashish Sah on January 13, 2011 at 2:56 am
    i m editing a film which is shoot in diff cam formate..sony pd-170(720*576 25fps)and sony hdv z1(1440*1080 25fps)..
    now after editing i hav to tranfer total film for digital cinema..
    they accept only 1920*1080 (24fps).
    whenevr i change my clips dimensions its totaly prixlet and frm doesnt look good..
    how can i upgrade its quality…
    Daniel Ludwig replied 15 years, 8 months ago 2 Members · 1 Reply
  • Daniel Ludwig
    January 13, 2011 at 3:42 am
    hi,
    I would upscal your SD-material using innobits purifier, but you need to know that HDV native resolution is 1440×1080.
    so I would upscale your HDV-material to 1920×1080 using purifier as well – maybe I would use the pro-res codec.
    then you need to do a frame-rate-conversion to 23.98p. this is quite a bit complex, but I wrote a small tutorial for this.
    https://blustreak.dvdafteredit.com/1080i50-2398p-workflow
    it´s been another context, but the workflow is the same.
    to use apples Cinema Tools is a common workflow for things like this.
    hope this helps
    cheers
    danny
