Activity Forums VEGAS Pro multiple audio fx on one audio track?
  • multiple audio fx on one audio track?
    Posted by Gerald Stokes on June 25, 2008 at 6:40 am
    Hello Again,
    I can’t seem to figure out how to apply multiple audio fx in one audio track. I have a 48min audio track, and during the track I need to apply different kinds of noise reduction etc, I don’t want the effect applied to the entire track, just the section I want. Now on video, it’s obvious as you have a green + next to each little clip and can change the fx on each seperate clip, when I go to an audio track and pick an fx, it applies it to the entire track. I’ve looked into automation etc and these seem to be for mute,pan and volume.
    Danny Hays replied 18 years, 3 months ago 3 Members · 3 Replies
  • Jeremy Rasnic
    June 25, 2008 at 1:47 pm
    The best option is the split your audio up on different tracks and apply the fx at the track level.
    The next option would be to split the audio and right click and apply your fx via the sub menu.
    j razz
  • Gerald Stokes
    June 25, 2008 at 7:32 pm
    I thought of that, then I starting checking out the different kind of envelopes, I wonder if you can apply fx envelopes to different sections of the one audio track?
  • Danny Hays
    June 25, 2008 at 7:54 pm
    Yes, you can use keyframes on your effects to apply them to a specific area or you can just split the wav before and after where you want to apply an effect and it will only effect the area between the splices. Thats the way I’d do it.
