Activity › Forums › Apple Final Cut Pro Legacy › Multiple audio dissolves
  • Multiple audio dissolves
    Posted by Ruben Rosado on January 22, 2009 at 3:48 pm
    Hello, I’m trying to add audio dissolves to a bunch of audio clips in a timeline. I know how to do it for video by dragging the the clips and using overwrite with transition but it doesn’t work with audio. Any ideas? Could it be done?
    Ruben
    John Fishback replied 17 years, 8 months ago 2 Members · 1 Reply
  • John Fishback
    January 25, 2009 at 9:49 pm
    I’m not in front of my edit computer right now, but I think this is right. If you highlight the junction of two clips then hit Option Command T it should insrt a 1-sec audio cross-fade. Double-click the transition to change its duration. To copy a transition from one edit point to another, try holding down the Option key while dragging the existing transition to another edit point. I think that works, too.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
