Activity Forums Avid Media Composer Multigroup error message with P2 footage?
  • Multigroup error message with P2 footage?
    Posted by Adam Davis on January 22, 2010 at 10:55 am
    I am working on an SD project in Avid Media Composer that was shot using miniDV and P2 footage. I am in the process of multigrouping some of the footage. When I try to enter an auxiliary TC for the imported P2 footage, I get an error message stating “Source Media Not Found.” I have not worked with P2 footage before and I have never run into this problem when grouping, so if someone could enlighten it would be greatly appreciated.
    Thanks!!
    Michael Phillips replied 16 years, 7 months ago 3 Members · 3 Replies
  • Ryan Mcafee
    January 22, 2010 at 2:33 pm
    With P2 after you have imported it. Select the clips you need, go back up to file, import P2, then click media. That might do it for you. If not I’m out of ideas.
    Ryan McAfee
    Moon Community Access Television
    http://www.MCA-TV.com
  • Adam Davis
    January 22, 2010 at 6:34 pm
    I have already done that… if only it were that simple.
    Thanks for response!!!
    Adam
  • Michael Phillips
    January 23, 2010 at 9:28 pm
    The AuxTC columns are dependent on sources having a TAPE source associated with it.
    Michael
    Michael Phillips
