Activity Forums Apple Final Cut Pro Legacy Multiclip workflow (XDCam EX vs. ProRes)
  • Multiclip workflow (XDCam EX vs. ProRes)
    Posted by Brett Blake on February 16, 2011 at 5:03 pm
    hey everyone-
    i’m working on a project that has 8 cameras in a multiclip. We ingested the footage as XDCam EX 30p, but are unable to play them back on a Powerbook with 2 x 2.66 processors and 16GB memory. we thought that maybe the problem was the codec, so tried recompressing the footage as ProRes and as ProRes Proxy (1920×1080 30p), but we’re still getting dropped frames, etc.
    is it simply unreasonable to expect the computer to handle this amount of footage at the same time, regardless of the codec? have tried turning on Safe RT, lowering the video processing quality, etc. and am still having the same issue. have even tried running off of a RAID0 drive, but to no avail.
    any help would be greatly appreciated.
    thank you
    Jerry Hofmann replied 15 years, 7 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    February 16, 2011 at 5:34 pm
    You need a beefier machine to not drop frames with that many cameras. You could just turn off the warning though…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
