Activity › Forums › Apple Final Cut Pro Legacy › Multiclip Question
Multiclip Question
Posted by Patrick Morrow on November 3, 2005 at 3:03 amWhen using multiclip, how do you determine what clip is 1 and what clip is angle 2?
Thanks!!!
Patrick MorrowDan Riley replied 20 years, 10 months ago 4 Members · 3 Replies -
Andy Mees
November 3, 2005 at 3:07 ami beleive the clip order is the same as displayed in the browser when you create the multiclip
Craig Seeman
November 3, 2005 at 5:28 amYou can apply angle names or it will use reel name (I believe) but it’s best to name angles so you have control over the order.
Dan Riley
November 3, 2005 at 5:33 amYou assign which camera is which when you capture.
There is a box for “angle” number in the capture window.
If you forget to do it or change you mind, you can select
the clip in the browser and change or add it.
If you don’t assign it, FCP will look at what you called
the clip and try to figure it out.Perhaps one could read one’s manual?
