Activity Forums Apple Final Cut Pro Legacy Multiclip Question
  • Multiclip Question
    Posted by Sassafras on November 14, 2005 at 11:57 pm
    I am trying to create a multiclip from four 1 hr tapes. That’s no problem. But I would also like to create this at 25%. Making basically a 4hr clip. I’ve tried to do this with 4 subclips at 25%, but i get the 4 angle multiclip, at 25%, but only 1 hour long. the first 25% of the material. The length of the original clips before the applied speed change. I’ve also tried to apply a speed change within the clip. But i end up with conflict errors or a lot of black angles. I guess I could break it up into 4 parts. but it seems there would be an easier way to do this. If anyone has any suggestions tips tricks or anything to try it would be greatly appreciated. This will be a big time saver for me if i can get it to work right. Much better than viewing the eight tapes individually at 25%!
    Thanks in advance.
    Sassafras
    Sassafras replied 20 years, 10 months ago 2 Members · 2 Replies
  • Mark Raudonis
    November 15, 2005 at 5:10 am
    I don’t understand what you’re trying to accomplish.
    Can you try to explain it another way?
    mark
  • Sassafras
    November 15, 2005 at 5:24 am
    Yes. I was afraid I made that too confusing. In the end what I would like to do is create a multiclip of 4 different captured tapes ( 1 hour tapes running at 25% because I need to view them at that speed to make selects). And i would like to view them all at once as a multiclip. Instead of 1 at a time. The multiclip would be 4 hours, and when I create the clip it is only 1 hour. Even though the individual clips at 25% are 4. This isn’t an issue with sync or anything real-time. It’s more about view four images at once instead of only one and creating a file of that length.
    sassafras
