Activity › Forums › Apple Final Cut Pro Legacy › multiclip needs render, what gives
  • multiclip needs render, what gives
    Posted by Todd Reid on June 26, 2010 at 3:40 am
    I have a concert to cut together, 5 angles, 5 codecs.
    I have gotten all footage in and the 4 angles that have the whole show are sync’d (5th camera was DLSR and didn’t shoot very much-I will add that in later). (no matching timecode by the way)
    Before you think you know what is wrong…I did take the time and used compressor to get all of the footage to ProRes 422 720p 1280×720 59.94fps, which matches my sequence.
    When all clips are layered for the sync, they dont require render. I make a multiclip, put it in the sequence and the render status bar turns red. So you know what happens now…I have to render to get it to play, then every time I make an edit it unrenders the rest of sequence.
    I’ve never had to do a HD multiclip, I’ve always been in the sd world and I didn’t have this problem.
    I’m currently running FC 6.0.6 & AJA IOHD
    Somebody please help jog my brain….what am I missing????
    John Pale replied 16 years, 3 months ago 3 Members · 2 Replies
  • David Roth weiss
    June 26, 2010 at 4:37 am
    Todd,
    I hate to say it, but most likely you don’t enough throughput on those RAIDs. What are the read and write numbers you get when running the AJA Disk Speed Test?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • John Pale
    June 26, 2010 at 5:46 am
    Try reducing the playback quality in the RT menu in the upper left of your timeline.
