Activity Forums Apple Final Cut Pro Legacy Multiclip Media Limits
  • Multiclip Media Limits
    Posted by Peter Srinivasan on August 14, 2008 at 8:04 pm
    4 Camera angles. They’re all synched into multiclips which are now waiting on my timeline. However, if I try to move the multiclip I get a Media Limits error. If I playback and attempt to cut angles real-time, even while on open sync, multiclip playback enabled, it will show the cutting as it should be happening during the playback, but it doesn’t actually cut in the timeline. After a collapse multiclip function, I still get media limit errors.
    Peter Srinivasan replied 18 years ago 2 Members · 2 Replies
  • Michael Sacci
    August 15, 2008 at 2:58 pm
    What format are your clips, what type of HD raid do you have them on.
    There are two live actions when using multiclip, Switch To and Cut To. Switch will give you Program Feed back and place markers as you play and switch the timeline. Once you stop playback everything is gone. This is the way it is designed to be, no idea why anyone would want this, guess it is a practice run. Normally it is set to do this when you hit 1, 2, 3, 4 on the key pad.
    Cut To does what most people want, the switching sticks at stop. Normally it is set to the combo Command 1, 2, 3, 4 on the key pad.
  • Peter Srinivasan
    August 18, 2008 at 5:43 pm
    I’m not sure what it did, it just fixed itself. Thanks for the switch/cut explanation, though.
