Activity Forums Apple Final Cut Pro Legacy Multiclip editing is choking during playback
  • Multiclip editing is choking during playback
    Posted by Michael Rothman on October 20, 2007 at 4:46 pm
    I just created a mulitclip using 6 angles and my computer is choking on playback. I just went and bought 4 more gigs of ram (totaling 6) to try to fix the problem and it’s the same as when i had 2 gigs. I’m playing back 720p prores 422 HQ. Does anyone have any tips. And my settings are on unlimitted and dynamic.
    Thanks so much
    Jeremy Garchow replied 18 years, 11 months ago 4 Members · 13 Replies
  • 13 Replies
  • David Roth weiss
    October 20, 2007 at 5:51 pm
    What type of hard drive subsystem are you using? that is, what type of drives, and how many are stripped together? That’s more important than RAM.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY™
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Michael Rothman
    October 20, 2007 at 5:59 pm
    Hey david,
    I’m using a Media Vault that has 10 drives. Its a fibre channel. Raid 3. It’s got 2 terrabytes of storage though theres 485 gigs left.
  • David Roth weiss
    October 20, 2007 at 6:51 pm
    That should be fast enough, but you should run a test to check the throughput. Do you have either the AJA or Blackmagic drive test? If so, run some tests and see what your numbers are. Its possible that your throughput is just not high enough for the number of streams you’re playing back in multicam. If not, your drives may be too full or some other issue is causing a bottleneck.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Michael Rothman
    October 20, 2007 at 6:59 pm
    I’m using an aja kona LH but i don’t have a drive test. It would be ashame if the guy recommeded all this ram, which isn’t making any difference instead of putting that money towards another drive to back up some of the other projects onto. Does all this ram even make any difference with final cut?
  • David Roth weiss
    October 20, 2007 at 7:39 pm
    They are both important, but if the drives are not providing the needed throughput your system will be hamstrung.
    Your AJA Utilities which gets insatlled in your Applications Folder has the AJA System Test. Run that a few times to test your hard drive throughput. After opening read the help files to mkae certain you run the proper tests and report back…
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Michael Rothman
    October 20, 2007 at 7:43 pm
    will do. and thank you.
  • Michael Rothman
    October 20, 2007 at 7:44 pm
    should i quit final cut while running the app?
  • David Roth weiss
    October 20, 2007 at 7:46 pm
    Yes!!
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Michael Rothman
    October 20, 2007 at 7:53 pm
    the test gave this info:
    Media Vault RAID/Disk Whack Test-
    128.0MB
    Write:344.3 MB/s
    Read:315.1MB/s
    in the options the volume was set to Media Vault Raid
    the video frame size: 720×486 8bit
    file size 128MB
    and Disable file system cache was checked
    Simultaneous Kona DMA was not checked.
  • Michael Rothman
    October 20, 2007 at 7:55 pm
    when i switched the file size to 2.0 GB
    the write was 320.0MB/s
    and the REad was 312.7 MB/s
